Upgrade door speaker options ?
sheepy92
Post by sheepy92 »
Anyone have any recomendations on best door speak setup and companys based around birmingham who could sort out a good system
Dav02
Re: Upgrade door speaker options ?
Post by Dav02 »
Not near Birmingham but I got this set and the difference is unbelievable.
https://www.crowncustomscaraudio.co.uk/ ... e-kit-vibe
2016 Caddy Highline. 2.0 TDi 102ps (ReMapped to 180)
Build Thread
sheepy92
Post by sheepy92 »
Cheers for the advice been looking at these plug and play kits they do a couple of different brands in the 6.5" size, few people seem to rate the vibes they also do the same kit with the optional amp but i have an aftermarket head unit with decent output.
Persum case of drilling the rivers on the old speakers to remove them also my van was the startline so no tweeters in dash so will deffo be adding them in
whelp
Post by whelp »
i got a set off Bass Junkies in Wolverhampton, makes a big difference, only about £50 off ebay as well.
It has the proper plugs for it as well, the fitting is in my build thread
Mick996T
Post by Mick996T »
Car audio and security do some really good deals
nate1
Post by nate1 »
I fitted a set of alpine SXE-1725S in my doors with the adaptor rings with some dynamat on the door skins and foam rings, Alpine SXE-0825S in the top of the dash where the factory tweeters would of been which are wired to the rear outputs so I can adjust them independently to the door speakers, Alpine SXE-1006TW in the wing mirror covers and a underseat sub to finish it off. not your top dollar kit but certainly does the trick for me
