Touran window conversion drivers window not moving
Lionwatton
Hey all, completed the conversion, everything else fine drivers switch moves passenger side, central locking fine, for some reason the drivers side just makes a click but the motor doesn't wind up or down, replace the window motor and still the same. Any help would be appreciated please. Tia
STP
Re: Touran window conversion drivers window not moving
Sounds like it thinks it's hit the trap sensor limit with the click?
Have you tried to disconnect the motor mechanically from the window and run it while plugged in but not on the door to see if the motor itself moves? I.e. don't hook it up to the window etc.
The window itself may be jammed or the gearbox is jammed or stuck.
When you set the up or down limit by holding the button, you get a click to indicate it's at limit and can't move further.
Best Caddy & Transporter upgrade content on YouTube: DTETV
