This is true as I found out on my 62 plate caddy. The peg on the leaf springs is part of the leaf and not removable like the earlier ones.
This is fine with the kw/eibach shackles as they come with a collar that reduced the hole size the lowest shackle plate and then located on the peg on the bottom of the leaf.
Not sure when they changed them but my leaf part number is 2k5 511 151 AA
Can I also just add that we are not saying all facelift Caddys (as we have fitted Vmaxx and axle plates to loads) but all New Caddys as in 2013 until we find out when VW decided to change them
Oh and back to the original post, you should be fine with an 11 plate but be quick because we have sold all our 55mm vmaxx kits and they are saying no more until August so it might be worth checking around
