rns 510 or rns 510 with dab
carp69
Re: rns 510 or rns 510 with dab
Post by carp69 »
hi did you undo the plug then feed the wires if so can you tell me how to undo the plug cheers
smeg
Post by smeg »
how does the mirror come apart
phanson
Post by phanson »
The hard way - as far as I know you have to pop the mirror out!
Many breakages later the technique is improving.
smeg
Post by smeg »
sussed it but no dab aerial :( wheres best place to get a vw one
gilly
Post by gilly »
If your not going for the factory look,why not fit a DAB shark fin/stubby arial on the the roof????
dan@biali
Post by dan@biali »
That's what I've got as there's no room inside the Touran mirrors for all the aerials. I think it's from a Tiguan part number 1K0035501J. You will also need the stubby aerial for it. Mine has fm, phone, gps, and dab so not cheap.
smeg
Post by smeg »
wanted the factory look need to get dab in the mirror
gram67
Post by gram67 »
Is it possible to fit n/s mirror dab aerial in a 2008 Caddy?
Thanks in advance
Banditbarron
Sales Caporegime
Post by Banditbarron »
Yes I have done it
carp69
Post by carp69 »
fitted the rns 510 whith dab and oem aerial in mirror and its the nuts
the long one
Post by the long one »
Question - will this work (dab only) with 2K5 035 525 J or do I need to get 2K0 035 525 K (only going to use the dab part)
Thanks in advance
Mike89
Post by Mike89 »
Ok. So, if I buy and rcd 310 with dab and fit it to my 2011 caddy, what else do I need to purchase? The loom to connect the radio to the mirror aerial?
A DAB antenna if you don't already have one.
