VW Leather handbrake cover with aluminum button installed.
Chris_Fz
Post by Chris_Fz »
This looks goods.
Sent from my SM-S908E using Tapatalk
Reason: Removed quote of previous post
-Vw Caddy Pv 2.0TDI 2015 stage 2 + 110wkw / 376nm -
-Nardo Grey & Black Trim
-Rolling on 19" A-line Hostiles
-Owner of Retrofitters
-+2771 027 5064-
AusCad
Post by AusCad »
Some really nice detail in your cabin. Magic place to be for you now.
It would be so nice to have accessibility to Touran parts in AUS.
Fantastic work! It’s a great thread to follow.
Thanks Chris and Auz.
Its changed a bit since I first got it :lol:
Gave the van a good cleaning this weekend.
Raph71
Re: Un Bon Caddy
Post by Raph71 »
Vraiment sympa Caddy !
Je n'oserais plus aller pêcher avec! :P
Hi Ralph,
Thanks very much. I couldn't imagine going fishing without the van, I get to combine my 2 favorite hobbies into one ;)
Wiring harness completed for push buttons for Park Assist, Tire Pressure and Electronic Stabilization. Everything wired per the VW Current Flow Diagrams.
Seen a CANbus extension harness on Ali Express so thought I'd get it and see what it was like, saves soldering. The 3 black plugs on the extension cables were crappy 3 pin ones so I took them off and put on some genuine VW 2 pin ones.
Installed a 5pin connector in the harness for the Scirocco gage pod, make it a lot easier to take in and out if needed.
Dale79
Post by Dale79 »
Hi fishermansfriend what a mint caddy you have built there , hats off to you, just a quickie regarding the van style arch kit you fitted , are they just double sided taped on ? Are they a nice fit, I,E no gaps ets ?
Thank you Dale. I didn't like the fit of them out of the box, the gaps were to big. The instructions say to glue on and they have double sided tape also but I didn't glue mine. I took the tape off and messed about with different thickness of tape before I got a fit I was happy with.
Dale79
Post by Dale79 »
Thanks for the reply mate , and keep up with the great work , tight lines ….
I didn't install the buttons/ wiring yet, I was looking for the correct connectors for the push buttons. After going through all the different colors I found the correct ones that fit without trimming the connector to make it fit, (1) 8W0971636B for the TPMS and (2) 8W0971636D for Park Assist/ ESP are the correct connectors.
jonnyboy82
Post by jonnyboy82 »
FishermansFriend wrote: Sun Jan 08, 2023 3:20 pm Gave the van a good cleaning this weekend.
Stunning :P
