Frost
Posts: 18 Joined: Sun Feb 26, 2023 6:48 pm
Post
by Frost » Tue Mar 14, 2023 8:23 am
FishermansFriend wrote: Brake pad wear sensor installed and coded.
Hi, this is a really nice and thorough caddy you have here. May I ask which part number your speedometer has?
Sendt fra min LE2113 med Tapatalk
Posts: 1034 Joined: Wed Jun 17, 2020 12:10 pm
Post
by FishermansFriend » Wed Mar 22, 2023 9:33 pm
Hi Dan, thanks very much.
FishermansFriend on Thu Apr 13, 2023 4:05 pm, edited 1 time in total.
Post
by FishermansFriend » Wed Mar 22, 2023 9:34 pm
Park Assist, Tire Pressure and Electronic Stabilization dash buttons installed and wired now.
Robert VW
Posts: 49 Joined: Sun Feb 26, 2023 7:27 pm
Post
by Robert VW » Wed Mar 22, 2023 9:54 pm
Well done
Why not go further ESC OFF and HDA?
Hill Descent Assist
Byte 6 bit 1 (0 -> 1)
Byte 14 bit 6 (0 -> 1)
ESC OFF
Byte 15
Bit 6 (0 -> 1)
Bit 7 (1 -> 0)
Post
by FishermansFriend » Thu Mar 23, 2023 9:26 am
Hi Robert,
Thanks for the tips, I will have to do some research. Do I need a dash button for the Hill Descent Assist?
Dislexicdonkey
Posts: 250 Joined: Sat Sep 28, 2019 9:43 pm
Post
by Dislexicdonkey » Thu Mar 23, 2023 9:43 am
Lovely build and some real nice touches on this mate. Just spent an hour reading this!
Well done mate
Post
by FishermansFriend » Thu Mar 23, 2023 10:36 am
Thanks for taking the time to read through it Dislexicdonkey.
Robert VW
Post
by Robert VW » Fri Mar 24, 2023 1:51 pm
FishermansFriend wrote: ↑ Thu Mar 23, 2023 9:26 am
Hi Robert,
Yes you do.
Just run fused ignition feed via switch and bring it to PIN 8 on your ABS unit.
fishynos72
Posts: 326 Joined: Mon Aug 24, 2020 10:12 am
Post
by fishynos72 » Sat Mar 25, 2023 3:00 am
Firstly- love this thread, for the OEM mods, and the nice photos.
The hardest part would be having a button made for the Hill decent control that fits in the mk4 caddy dash.
Someone like double-apex might be able to help
Post
by FishermansFriend » Sun Mar 26, 2023 1:42 pm
Thanks for the info Robert.
Post
by FishermansFriend » Sun Mar 26, 2023 1:43 pm
Hi fishynos72, thanks again. Yes having it look right would be the hardest part. Thanks for the contact, ill check them out.
Post
by FishermansFriend » Sun Mar 26, 2023 1:48 pm
Been tidying up the fuse box the past few days, it was a mess. I re-run all the wires that were added since I got the van and got rid of the fuse holders that plug into the front of the fuse box, re-pinned with terminals into the back of the fuse box. Followed the OEM routes as best I could and labeled the wiring I had added.
Install the CAN Bus extension cable also, really handy to add more wiring to the CAN Bus now.
DW2207
Posts: 888 Joined: Tue Oct 01, 2019 8:49 am
Post
by DW2207 » Sun Mar 26, 2023 2:28 pm
Nice job there, it gets quite tight behind these fuseboxes
I remember when I was looking for the correct cable ferrules for the rear pdc sensors I fitted on my mk3 caddy. I must have spent weeks searching for the correct name for them so that I could crimp and push the 12v in the correct fuseway of the box haha.
I won't forget these in a hurry 'junior power timer '
Post
by FishermansFriend » Fri Mar 31, 2023 5:09 pm
Gave the dash top box another sanding to make it fit a bit better.
Post
by FishermansFriend » Fri Mar 31, 2023 5:45 pm
Had the van polished recently.
